GP MALASIA : INFO, COMENTARIOS Y MAS
¿ QUIEN GANA EL GP DE MALASIA ?
Puede seleccionar 1 opción
Ver resultados
Re: GP MALASIA : INFO, COMENTARIOS Y MAS
black demon ek9R escribió:recuerden que es una pista de alta, con 2 grandes rectas y si autorizan el drs, veo que los maclarens les puede ir bien por la potencia del motor mercedes
ya quiero que sea fin de semanaaa
Te lo pedimos señorrrrrr !!!!
http://www.youtube.com/watch?v=WzFofrFP ... re=related
que mal ....... :oops:
ABIERTOS LOS PRONOSTICOS DE ESTE GP, GORRA FERRARI DE PREMIO...
viewtopic.php?f=71&t=31499
WTF ??
Luifer
Mensaje sin leer por Luifer »
Villamas escribió:WTF ??
:alien:
Diay mae es un fan por todo lado que lo mires..... Eso es bueno! :ok:
Red Bull – KERS installation detailed
via Motorsport Magazin
Having run KERS for Friday only in Melbourne, RBR will probably run the KERS system for the full weekend in Sepang. As RBR were not seen to use KERS on their qualifying laps, although they were unknown to be equipped with Renaults KERS raised rumours of a start only KERS. While a start only KERS is technically legal and has some technical advantages, it’s not thought such a system is planned for any team.
From images seen this in the team’s garage this morning we can see the KERS set up quite clearly. The actual set up is quite different to the image provided by Red bull in their Launch press pack. Which shows a far more conventional layout?
KERS control unit - Via Autosport.com
On the right hand side of the car, we can see a silver box with FIA anti-tamper seals; this is the KERS control unit (KCU). This controls the power exchange between the motor generator and the battery pack. The thick red cables carry the current in between these other devices. Running very hot from the current passing through it, the KCU will have a cool air feed from the sidepod ducting. Although not certain, the small radiator at the bottom of the other coolers is probably to cool the battery pack.
Possibly the KERS water cooling radiator - via Autosport.com
From the other side we can see the Battery pack, unusually this is mounted to the side of the gearbox. It is the rounded carbon fibre item, with the yellow warning sticker.
ImagenKERS Battery Pack - via Autosport.com
The other three KERS suppliers (Mercedes, Ferrari and Williams) all place this item beneath the fuel tank for better weight distribution and crash safety. Although McLaren did place theirs low down in the front of the sidepod in 2009. With the more rear biased mandatory weight distribution rule, this more rearwards location is not a handicap. It frees up fuel capacity and sits inside a dead area of space within the sidepod. You can see the same thick red cable emerging from the battery pack. Inside the carbon case will be an array of small lithium-Ion cells (Li-ion). These will run at high temperatures as the cells charge and discharge, as explained they will be cooled a dedicated water radiator and pump.
http://scarbsf1.wordpress.com/2011/04/0 ... -detailed/
Mis amigos foreros los invito a instalar la barra mm.com
https://s3.amazonaws.com/com.alexa.tool ... /index.htm
Quattrovalvole
MM.COM escribió:Mis amigos foreros los invito a instalar la barra mm.com
¿Cuánto paga?
Sia guevon!!!
El tipo de tattoo que uno dice...WTF!!!
Por ejemplo!
Captura de pantalla 2011-04-08 a las 07.27.41.png (74.7 KiB) Visto 3660 veces
pelon
Mensaje sin leer por pelon »
Igual que la anterior le voy a Vettel, aunque ponerle el ojo a Webber
Héctor Gutiérrez V.
Fermava
Jaja, que loquera el mae, pero que arte de tattos!!! Bien hechitos, desde los de Shumi, la F1 ya hasta el del MU.... Su vergo de plata tiene invertida ahí...
Quattrovalvole
Que espantosamente feo , se reventó esa llanta. :bom: Sola, sola, sola. Yo no veo absolutamente nada en pista que la haya hecho volar así.
Y que suertudo Petrov......, solo una piedras en el casco.
Un lote defectuoso de material, el problema de Lotus Renault
El ruso Vitaly Petrov trompeó y se fue a la grava por la mañana como consecuencia de un fallo en la parte izquierda delantera de su coche. Mientras que su compañero de equipo , Nick Heidfeld, se veía obligado a volver al box cuando la rueda delantera derecha de su coche quedaba atascada.
Entonces, el equipo decidió dejar de correr hasta que el problema fuera investigado. Tras la investigación Lotus Renaul ha concluido que se trataba de un problema en un lote de material que ha salido defectuoso y que nunca antes les había ocurrido.
James Allison, director técnico, declaraba: "Rápidamente establecimos que los dos componentes fallidos provenían del mismo lote de material y, nada de dicho lote había fallado hasta hoy. Llevará más tiempo encontrar otras causas potenciales, pero una vez que estábamos confiados en que los fallos estaban relacionados con un problema de material dejamos salir a los dos coches para la segunda parte de los entrenamientos libres de la tarde, donde corrieron sin problemas".
Fuente
Que guapo el Hispania
http://www.hispaniaf1team.com/images/phocagallery/2011/02_KualaLumpur_April2011/thumbs/phoca_thumb_l_d11mal675.jpg
Villamas escribió:Que guapo el Hispania
pelon
Issh vale que parece que no es pesado y no quedo prensado...
Héctor Gutiérrez V.
Maldonado ayer en FP2
Salida de pista de Michael Schumacher en FP2
Liuzzi con problemas en la FP2
Para los colorados!
:lengua: :lengua: :lengua: :lengua: :lengua: :lengua:
toyo_jr
pmontero escribió::lengua: :lengua: :lengua: :lengua: :lengua: :lengua:
horrible cosa ese 5 y 7 de Ferrari para la partida....
:manos: :manos:
Juan Ro
Si mi pronostico del Top5 hubiera sido para la clasificacion y no para la carrera, casi que lo hubiera pegado... :lengua:
guanabi
jajajajaja, tranquilos mis amigos tifosis...
que Ferrari y Renault vamos palmo a palmo... jajajajajajaajaja (y con la quinta parte de "pilotaje")
que tuanis ser pancista !!!!!!!! :descojonado:
