ASI Q ESE NEGRO ME PUEDE BESAR....
LEWIS: "Raikkonen no tiene pelotas para frenar más tarde"
Re: LEWIS: "Raikkonen no tiene pelotas para frenar más tarde"
Lo dice el piloto que no pudo frenar bien ni siquiera en boxes y termino paseandose en la carrera de Kimi!!!!!
Declaraciones de otros pilotos respecto de la controvertida maniobra... para que después no digan que sólo los de Ferrari! Mis disculpas pero no encontré esto en español, son sacadas directamente de la conferencia de prensa de hoy viernes... y todos estos señores coinciden en que Lewis sacó ventaja de cortar la chicana.
Bourdais: I think the rules are very clear. Maybe the penalty was a bit hard, but I think he's made the same mistake twice: he's done it in Magny-Cours and he's done it again in Spa. I don't really understand why there's been such a mess around it. There's a rule book and everybody has to obey the same thing. The penalty is really rough but in the end it's up to you to give the position back or not. Pretty straightforward. I think it was very clear and I agree as well. You have to be responsible for what you decide to do, and in this particular case, if you do gain an advantage like I said, you just give it back and make sure that you don't expose yourself to penalties. I think it's the easiest way to handle it. The rules are available for everybody to read I think and they are very clear. You gain an advantage, you gain an advantage. It doesn't matter how big it is, if you end up being in a position to pass at the next corner then you gain an advantage, because at that place, as everybody said, you are never going to be in a position to pass, if you exit the chicane normally behind the guy, because it stretches out, it's normal. It's very simple, I think.
Rosberg: Yeah, I definitely agree, because he did get an advantage, because he wouldn't have been that close behind Kimi had he not cut the chicane. But then again, I also think the penalty was a bit harsh as that did not have such a big effect on the actual race result in the end.
Fisichella: I have just seen pictures, so it is difficult for me to say whether what happened was right or not. For sure, maybe, he took a small advantage, that's why he had the possibility, as Felipe said, to overtake him again in braking for turn one. But obviously, a 25s penalty was quite a strong penalty.
Trulli: Well, I agree completely with my colleagues. The penalty was quite big but I'm not a steward and I cannot decide what kind of penalty should be given. But on the other hand, it was very clear that he got an advantage out of it, so that's where it is. The rules are very clear. If you cut the chicane and you get an advantage, you just have to drop back and give back the position and in Lewis's case he shouldn't have attacked straight away at the next corner; that was it. On the other hand, with this new chicane, there is a lot of run-off, it gives you more chance to attack because in the case of a mistake, you wouldn't end up in a wall or in the gravel. If it was the case of Lewis in Spa, he wouldn't have gone much further than that. We have more chances to overtake.
- Rocketman
Seguimos? NO!! Paramos? NO!! Seguimos?? NO!!!
Mas claro no lo pudieron haber dicho.
De no haberse brincado la chicane, no hubiera estado así de pegado a Kimi. Lo dice Jarno, lo dice Sebastian, lo dice Pedro, lo dice Clio2.0. Ferraristas y anti ferraristas lo pueden ver. Solo los McLaten fanboys deciden ignorarlo.
Y pues sí, Lewis tiene así PELOTOTAS, pero para ventearse todo lo que se llama jeta!
Big Mouth Rockets
Big Mouth Rockets
- toyo_jr
Mr. Cohete es muy fácil no lo ven porque no lo quieren ver... no les conviene...
Juan Ro
- escholl
Sauron escribió:Lastima que ya no está Takuma Sato![]()
Si Kimi no tiene bolas, Hamilton no tiene cerebro
pero como te emociona el cirqueño ese, papito, jajajajajajajajajajaja
como dice el dicho, no peca, pero incomoda, hamilton es mejor que todos, menos que Alonso.
jajajaja....
Bueno... luego de leer todo y cagarme de risa un rato...
Bien dicho por los demás pilotos... salado Hamilton... pienso que si bien el castigo fue duro, está bueno, para que aprenda por necio, es que este mae sí que parece que hace las varas al propio, como por joder...
Es como un chiquito necio que no le importa un bledo lo que le digan... jajaja..
Pero en fin... el mae maneja un vergazo y va de primero... vamos a ver en qué termina el campeonato
- Rocketman
Ufalaaaaa
Sias perro mae, vale que sos ferrarista...escholl escribió:como dice el dicho, no peca, pero incomoda, hamilton es mejor que todos, menos que Alonso.
Yo sé mae, yo sé. La hablada de que no hay que ser ciego ni envenenado, etc, etc. Pero ufa mae, guacala. Hágale barra a McLaren entonces...
Para mi Hamilton es bueno si, sin embargo además de bueno, tiene mucha suerte y llegó a McLaren F1 en buen momento.
Yo no soy envenenado, soy apasionado ferrarista a muerte. Y no es que sea ciego, porque cuando los maes la cagan, me les recontra cago en todo lo que se llama maire, como a Massa el año pasado en Malaysia. Pero cuando se trata de defenderlos me pongo la chema roja y vuelo manazos, los mejores para mí siempre son LOS ROJOS y punto. Aunque le admita el talento de los otros, Alonso incluido. Repito, no soy envenenado, NO GUEVONNNNNN, ENVENENADISIMO...
Y bueno, si Lewis es tan, pero tan tan rebueno, por que no viene repichaseando en el campeonato teniendo el mejor carro? No me vengan que por lo de Spa, porque les contesto que entonces si en Hungría no revienta el motor la vara vendría igual de parejo, y eso que según muchos aquí, Massa no sirve para un carajo...
FIERCE, FIERY RED GLOWING Rockets
- estebanvenon
Increible todo lo q este tema saco a la luz...
Cosas en las q si estoy deacuerdo:
1- LH se pego a Kimi cortando en la chicana.
2- LH es el q no sabe frenar... mucho carro un Mclaren para el grone.
3- LH nunca sedio la posicion.
Cosas que NO esoty deacuerdo:
1- Alonso es mejor que todo el mundo ahi...
(Sorry pero 100% fiel al asturiano)
Como que a L.H. se le olvidó el botonazo del año paso. Un supuesto botonazo, mas un despiste y Kimi, el que no tiene bolas ahora anda el número 1.
- escholl
mae don cohete, tranquilo, no me vas a decir que de verdad vas a celebrar un campeonato con Massa, por favor,
Ferrari es el equipo que simpre me ha gustado pero no por eso me tapo los ojos y no veo a los demas, para mi, ojo, Hamilton es mas piloto de carreras que los demas, ese no se queda solapado detras de nadie y hasta irreverente es.
Que decian del mal querido Montoya, se echaba a Schumi donde fuera y todos le caian encima, esos pilotos hacen falta hoy dia, maes con ganas de ganar, de pulsearla hasta el final, o nos quedamos como estamos.
Pero Massa, no por favor, no mas.
se lo cambio por Trulli o Bourdais !!!!
y despues de ayer sigo pensando ke en parte tiene razon Lewis H.
- Accord
Yo no, pero al verlo pasar a Raikkonen en mojado esta vez taaaan fácil, si bien estaba más mojado, se queda uno pensando si lo hubiera cazado en Spa en esa rectica. Conjeturas.......Cesar escribió:y despues de ayer sigo pensando ke en parte tiene razon Lewis H.
:D
Hoy por hoy el maclata es el mejor carro, los demas tienen que pelear con lo que tienen.... y asi son los campeonatos, mamilton llego a maclaren en un buen tiempo pero sigue sin convencer como buen piloto.
A criterio personal hay pilotos mucho mejores que la chocoleta dentro de los cuales y en ese orden estan Alonso, Kimi, Massa, y el resto acomodenlo como quieran.
Lastima que no tenemos carros mas parejos para que se den cuenta que la chocholeta no es lo que parece ser
Adrián
- Rocketman
No entiendo...
Mae. Hay dos pilotos en Ferrari hoy en día. Solamente DOS. Uno le lleva veinte puntos al otro. Los dos han tenido una carrera en la que se les quebró el motor. Los dos tuvieron varonazos a principio de año. Los demás, corren para otros equipos, algunos mas talentosos que otros, algunos se me hacen más simpáticos que otros. Al final del día lo que me interesa es que sea el carrito rojo el que gana. Pero no voy a ser tan judas como para venir a echarle flores a Hamilton, porque digan lo que digan, no me ha deslumbrado en ningún momento, y aunque sea el novato de la historia, mientras no corra para Ferrari, me pela el eje.escholl escribió:mae don cohete, tranquilo, no me vas a decir que de verdad vas a celebrar un campeonato con Massa, por favor,
Disculpen la analogía tan chabacana que voy a usar, pero mucha gente solo así entiende: Es como que yo fuera Saprissista y le celebrara a La Liga que le gane 3 a 0 a Saprissa porque fulanito es un excelente jugador! JOAS!!! Que se pudran los desgraciados, fué trampa y el árbitro nos robó el partido!! Comprendes Mendez? No freaking way. Si uno es Tifoso, le hace tifo a La Scuderia, a Hamilton que vea a ver quien lo infla.
A Kimi lo respeto desde que Peter Sauber lo contrató para su equipo, mientras corrió con McLaren siempre me cuadró el manejo del mae. Puro talento, pura velocidad.
PEEERO. Hoy, 15 de Septiembre del 2008, Felipe Massa viene vergueando a Kimi Raikkonen, hasta por debajo de la lengua lo está atendiendo, aún cuando Kimi es campeón y empezó el campeonato con todo el favor y apoyo de la afición, los medios y el equipo. Con todo y todo, es Felipe Massa el que viene peleando el campeonato. Compare las estadísticas de Kimi con las de Felipe este año, y dígame usted por qué FRUTAS no le voy a hacer barra a Felipe y como carajos es posible que algún ferrarista diga lo contrario??
Que el mae no es el mejor en lluvia? Me pela, talvez el carro no sea el mejor en mojado. Ojo, TALVEZ. Igual, no pongo excusas y me pela un banano lo que digan. El que le ha peleado el campeonato a Lewis este año y hasta este punto es Felipe, y por un par de carreras malas no lo voy a juzgar, porque igual ha tenido sus momentos brillantes, por los cuales lo respeto. Y lo he respetado desde que era test driver de Ferrari. Con un par de parentésis por sus indecorosos deslices, pero quien no.
Bien por Vettel, que buenazo tenerlo de rojo en el 2011...
Le aplaudo un campeonato a La Scuderia siempre. I pledge allegiance to the flag, MY FLAG, the checkered flag.
Follow The Rocket
- toyo_jr
Acabas de describir exactamente amigo Rocket lo que es ser un tifoso...
Hamilton puede ser la mamá de Tarzán envuelta en huevo y servida para el desayuno, pero no es un piloto al que apoye pues no está montado en una Ferrari (y tampoco lo va a llegar a estar)
Un campeonato de Felipe uno que se llame Tifosi lo celebrará, porque no es el campeonato de un piloto nada más un campeonato ganado por un piloto de Ferrari....
Juan Ro
+1toyo_jr escribió:Acabas de describir exactamente amigo Rocket lo que es ser un tifoso...
- rtlplus200710210814xq4.jpg (281.73 KiB) Visto 1088 veces
